Business processes can be run, like a workflow, based off a starting rule. They can also be run manually from the Workflow Designer, the Workflow Administration Console, and the Laserfiche client applications.
Run a business process from the Workflow Designer when trouble-shooting or analyzing the design of your business process definition by using the Run Current Workflow option.
Business processes can be run, manually, from the Laserfiche client applications when their business process rule is satisfied. Learn more about starting a business process in the Laserfiche Client or starting a business process in Web Access.
A business process can be invoked by a workflow or another business process that has been configured with the Invoke Workflow activity.
Business processes, like workflows, can be assigned starting rules. You can assign starting rules instead of, or in conjunction with, business process rules. A business process that is assigned a starting rule will run when a set of predefined conditions are met or when a specific schedule occurs. If assigned a starting rule, the business process will run on the following occasions:
Business processes assigned a schedule starting rule can be manually run from the Schedules Node in the Workflow Administration Console.
This documentation is specific to version 9.0. You can find the most up-to-date help files for the latest version at Current Online Laserfiche Product Help Files. For further help or feedback, please see the Laserfiche Support Site. |
© 2013 Laserfiche |
